5.13 or ?
Old Jun 12, 2012 | 05:16 AM
creepbam's Avatar
Default 5.13 or ?
Hello all, I'm wondering what gear ratio would be better suited for my Rubi. I have a 07 2dr auto currently with 35's. I find the lost in power manageable except on highway driving. I am wanting to upgrade my gears and have read up a lot on 5.13's and i believe its 5.33's or 5.38's( i cant remember). I'm pretty sure I'm going to go to 37's whenever i wear out my 35's, but its not in stone. I was wondering and there is such a big difference between the 2 that if i went with one it wouldn't be enough or it'd be too much. Like if I stayed with 35's and went with 5.38's and it was too much or i end up going to 37's and went with 5.13's and it wasn't enough. Opinions are incouraged! I go wheeling quite a bit, Its probably 50/50 on-offroad. It a lot of low-speed crawling, trail riding.
Old Jun 12, 2012 | 05:24 AM
shelbygto2's Avatar
I have 5.13s with 37s and they are great! I can do 70mph all day no probs. and only at about 2300rpm (auto). Get them, you won't regret it. I'm going down to 35s and I think they will be even better then.
Old Jun 12, 2012 | 05:29 AM
creepbam's Avatar
Thanks for the input, nice to see another Texan with a badass JK lol.
Old Jun 12, 2012 | 05:57 AM
creepbam's Avatar
bump. more opinions please!
Old Jun 12, 2012 | 06:05 AM
wayoflife's Avatar
JK-Forum Founder
with 37's, 5.38 is a nice ratio to have that will give you a bit more power but, the pinion will be very small in a dana 44 and will be a weak point. if you play hard with your jeep, i personally would recommend that you forego power for strength and just stick with a 5.13. the difference really isn't that much. but hey, that's just what i would do.
Old Jun 12, 2012 | 07:28 AM
silverbackjk's Avatar
is it ok to run 5.13 in a dana 30?
Old Jun 12, 2012 | 07:29 AM
Default 5.13 in a dana 30
Is it safe to run 5.13 gears in a open dana 30? I don't want to risk strength. I will not lock the front but will have the non rubi danna 44 locked Arb.
Old Jun 12, 2012 | 07:43 AM
wayoflife's Avatar
JK-Forum Founder
yeah, you can do it and so long as you keep the front open, you should be fine.
Old Jun 12, 2012 | 08:21 AM
creepbam's Avatar
Thanks WOL for explaining the downside of the 5.38's, i did not know that! Looks like i will be getting 5.13's
Old Jun 12, 2012 | 10:03 AM
KSCRUDE's Avatar
I have a 11 2 door auto with 4.88 and stock size 32 inch rubber. I never plan to go bigger or I would of went 513. Still should of as I now run 2500 at 70mph and would only be around 2600 with 513. I have a dana 30 up front in my sahara. Anybody wanting to go anything bigger then stock rubber should just get the 513 and be done with it. If you have a rubi go with the 538 in the 44 danas. Anything else is a waste of money. This is for the 7 to 11 auto wranglers with the 4 speed auto which comes from the factory as a design flaw in every automatic made as even the 410 is not suitable for everyday driving with stock tires and the 3.8 with auto. The most miss geared vehicle I have ever owned, until I installed 488 Yukon gears. And don't worry about the pinion gear in a Dana 30 if you buy Yukon or other good brand and have the installed by a professional gear head! You won't breakem!
