**Edit for accuracy
lets establish some things. Rim width is from bead seat to bead seat. an 8" rim is really about 9" wide, lip to lip. BS and offset are 2 different ways of measuring the placement of the mating surface in relation to the rim. The difference is that bs measures in inches from the back rim lip to the mating surface and offset measures distance in mm from the rim centerline to the mating surface. on an 8" rim with 4.5" bs, the offset would be 0. As you increase bs, offset would go positive and if you decrease bs, offset would go negative. Go here and mess with the #s to see for yourself: http://www.rims-n-tires.com/rt_specs.jsp On the Cragar soft 8 issue. I am curious as to where the rubbing occures for those that have problems. Is the rim center rubbing on the face of the caliper or is the outer rim rubbing on the outside edge of the caliper? My guess is that cragar got 2 batches of rim centers. On mine, the holes on my soft 8s protrude inward a bit and come pretty close to hitting the caliper. |
I'm looking at the Pro Comp series 152 street lock which looks to be the same as the Cragar street lock 352's. The backspacing is 3.75" same as the cragars. Will the Pro Comp wheels in 15" fit as well? I'm looking to do 33 x 12.5 tires as well, will this pose a problem?
Any word on the mickey thompson II 15's rubbing?
Originally Posted by merfsiu
(Post 402188)
**Edit for accuracy
Originally Posted by RedneckJeep
(Post 402563)
Yeah, kinda like the pic I posted. :crazyeyes:
(Post 402590)
You keep saying that BS and offset are 2 different things when they both do the same thing, that is quantify the placement of the mounting surface in relation to the rim.
Agreed...the only difference between offset and backspacing is where you measure from in relation to the mounting surface. Offset measures either negitive or positive from the centerline of the wheel, where as backspacing is measured from the back lip of the rim... You cannot have two rims of the same width with identical backspacing and different offsets... PS....list updated!!! |
Originally Posted by sgtsasquatch
(Post 402537)
(Post 400000)
That's all well and good, but ALL 15" Cragar Soft 8 4" bs do NOT fit. It's touch and go. Also, the backspacing has absolutely nothing to do with whether or not the wheel will hit the caliper. Not one bloomin thing.
i disagree... the BS helps, for lack of a better term, the widest part of the rim over the calipers... Eagle Alloys 185's 15x10 -45 mm BS is what i am running |
15x10's
Went to a shop today, jacked up my rubicon in the lot and tried on three different wheels. {Crager Soft 8 15x10, 4" BS--rubbed brake caliper} {Crager V5 15x10, 3.75" BS--rubbed brake caliper} {U.S. Wheel Black Daytona 15x10, 4" BS--fit fine}
Unfortunately they only had 2 of the U.S. Wheels in stock. I ordered two more as well as 35x14.5 Super Swamper Boggers. Hope this helps someone. |
Originally Posted by Rubicon Rando
(Post 405265)
