Sponsored by:
Sponsored by:
Help with very small lift.
Old 06-05-2007, 09:02 AM
nachoninja's Avatar
Default Help with very small lift.
I'm looking to get some 285/75/R16 tires and I would like to clear them with the minimum lift possible. I have aftermarket wheels with less backspacing so I'm only concerned about rubbing on full articulation. Does anyone know if a 3/4" coil spacer lift will do the job? Or will I need to go to a 1 3/4" spacer lift(From Daystar).
Also, does anyone with any more experience know if I'll need anything else such as new springs or shocks if I opt for either of these kits, or is the lift small enough that it won't adversely effect my driving or any of my stock components.
Thanks again for the help.
Old 06-05-2007, 09:10 AM
nachoninja's Avatar
Just to add to my original thread, according to a tire size calculator the 285's will only be .78 of an inch taller than the stock tires, so I would think a .75" spacer lift would do the job, as I don't think the .03 of an inch will cause too much trouble.
Old 06-05-2007, 09:12 AM
JeepSWAG
Sponsoring Manufacturer
Woods's Avatar
You might get a better response if you converted the tire size from metric to standard. Just google metric tire conversion calculator.
Old 06-05-2007, 09:26 AM
nachoninja's Avatar
Also, would bump stop extensions be required with the 3/4" spacer lift?
Old 06-05-2007, 09:30 AM
az.hunter's Avatar
Default ...
Would he even need a lift...???
Old 06-05-2007, 09:39 AM
jeepinoutwest's Avatar
i run 285/70/17 (should be exactly same height) with no lift, no rubbing.
Old 06-05-2007, 09:42 AM
bim6180's Avatar
33" tire with no lift is good, but will rub on full flex with sway disconnected.
I put up some pic on this thread:
https://www.jk-forum.com/forums/modified-jk-tech-2/re-2-bb-isntall-just-finished-9422/
That's with 33" tires (285/75/16) and Rubicon Express 2" BB. I've seen one here at my local shop with 33" tires and 1 3/4 daystar kit, and it looks sharp as well.
Old 06-05-2007, 09:48 AM
nachoninja's Avatar
Cool, thanks for the help. Does anyone know how much of a front lift is required so ther is no rubbing when the sway bar is disconnected?
Old 06-05-2007, 10:06 AM
armycop's Avatar
The 3/4" spacers will be enough for 33's, I went with the 1 3/4" Daystar and have plenty of room.
Old 06-14-2007, 10:42 AM
GraysonJeep's Avatar
https://www.jk-forum.com/forums/showthread.php?t=9422
my wife's jeep will not have the sway bar disconnect ...ever. she uses at her daily driver and just a few mud weekends, so am I correct in seeing that she should be fine with a 33" tire? she just doesnt want it to rub if she has the wheels turned all the way in one direction.
She is wanting a set of black rims to compliment the Jeep. Still looking for the correct set with backspacing that is going to be ok with a 33" tire
Quick Reply: Help with very small lift.
