adapter harness for front turn signals?
getin ready to add resistors to the front turn signals so i can run leds but really dont want to tap or splice into the factory harness. Does any one know of an adapter type harness that can go inbetween the factory plug and the turn signal plug i can splice it for a resistor? Dont want recons before any one mentions them.
ty for any info : )
ty for any info : )
50w 6ohm resistors. you connect one lead to the black wire coming out of the turnsignal plug and then you connect the other wire from the resistor to the outer most wire on the turnsignal plug. i spliced mine in about 3 inches back from the plug so i had plenty of wire to work with.
