Adding 2" spacers to a 4" suspension lift
I think the higher suspension lift needs after market drive shafts, higher bump stops, extended brake line or brake line brackets, adjustable track bars.
In my opinion, adding 2" spacers to the existing 4" coil springs will not be so reliable.
You're looking at a whole bunch of stuff for 6 inches of lift.
I'm not sure what you already have, but check out the FAQs for some help.
https://www.jk-forum.com/forums/show...272#post211272
6" of lift is a lot of lift and you'll need more than just longer brake lines. really, you need a complete kit with adjustable control arms, dropped pitman arm, track bar relocation brackets, adjustable track bars, longer shocks, new drive shafts, etc. in truth, at this height, you really should be looking at long arms too.
