Adding front lca's to aev 4.5 suspension?
So the ball joints and the tie rod are bad, and they are the cause of the bumpsteer. Gotcha.
I did read it, and it sure didn't sound like you had actually checked anything. It sounds like you are just assuming. So you don't know what the cause of the bad handling is, and you are just wanting to throw money at it hoping you get it right. Right? What is the purpose of adding control arms? If the caster is already handled by the brackets, what are you hoping for from the arms? Maybe it's just me, but I think the better course would be to actually find the problem and fix it, rather than just slapping on new parts and hoping. But it's your money...
I can't remember - you running hydro assist?
My steering dances around over bumps. I'm running 37’s and beadlocks which probably weigh 25lbs less in each corner than your set up.
I just replaced bj's, tie rod, draglink, and track bar bracket about 1000 miles ago. Still does it...
I don't recall anyone saying that steering stabilizers don't work. What they have said, again and again, is that if you have a steering issue --> it is better to FIND and then FIX the issue rather than slap on a heavy duty stabilizer to MASK the issue. Kinda like this thread. Instead of finding and then fixing the issue, let's just throw random parts at it and maybe it will go away.
really the easiest fix is what you plan on doing ie the ball joints if they are indeed bad but I doubt they are at 6000 miles unless you are hammering off road. its the tires. See if you can borrow some 35-12.5-17 tires/wheels and see how it feels. 15.5" tires are going to be all over the road following the grooves etc. The good thing is your AEV 4.5" should be easy to unload when you upgrade.
Same reason i removed my brackets.
Do you have ADD or are you just being an Dick? Im betting on number two! I CLEARLY said that I would have my shop check out everything, therefore Im not just "Throwing" parts at it. I also CLEARLY said that based on my last rig, the ball joints were TOAST at 5k miles, so I know these are as well. Since you have nothing positive to contribute, stay off my thread!
I wont ruin your threads by posting again but still would try to borrow some smaller tires to give a try.
