Adjustable trac bar
I picked up a rubicon express adjustable rear trac bar. My axle needs to go 3/4" to the passenger side. Problem is that at the shortest adjustment the axle still needs to go a 1/2". I really don't want to go through the hassle of removing and sending back / exchanging. Am I alright leaving as is, or should I order another bar? At least I have the added strength of a chromoly trac bar now.
Jeep has 4" lift, sleeves, gussets, control arm skids, adj front trac bar, and 35's
My adjustable track bar was far too long on my 2.5" lift (barely 2 in the rear) so the rear bracket ended up coming out. I just run straight to the axle. A 4" lift is another issue. A good bracket like the Teraflex one has a couple of spots to mount the track bar to, is yours just a fixed length?
No, mine is adjustable. It's for a 4" lift but at the shortest length, it's still too long. My axle needs to move to passenger side , which is weird because with that amount of lift you'd think it would need to shift to drivers side?
It sounds as though you need a shorter tracbar that is designed for a shorter lift. If you purchased the tracbar new; you can either try to return it for a shorter tracbar or trade with someone that needs a longer tracbar designed for more lift.
