AEV High Steer Kit Anyone?
Anyone using the new AEV "high steering Kit" yet?
Thought, opinions?
https://secure.aev-conversions.com/store/merchant.mvc?Screen=PROD&Product_Code=NTH20405AA
Front Steering Correction optimizes steering and roll center geometry for ultimate precision and control. Also allows larger/relocated steering damper and relocated stabilizer end links.
Geometry-Corrected™ “high-steer” kit:
* Tie-Rod 'flip' via tapered insert and new OEM-grade draglink.
* Brackets to relocate the track bar, stabilizer end links, & damper.
Thought, opinions?
I think you get more for your money with the TeraFlex JK Wrangler HD Frame Brace and Drag Link Flip Kit.
http://www.teraflex.biz/products/jk-...-flip-kit.html
The HD forged front flip draglink has been designed to solve several front end issues with lifted JK Wranglers. The new draglink is 'flipped' over the knuckle, and uses a new tapered insert to mount the draglink into the knuckle. The HD draglink is 50% stronger than the factory draglink to hep eliminate front end shimmy and other alignment issues. The forged draglink will thread into the factory adjusting sleeve. This draglink is designed to work with lifts over 4". The kit also includes a frame side trackbar drop bracket to keep steering geometry correct, and a frame brace strengthens the frame to further reduce any front end shimmy or excess movement.
Welding is required.
Only thing that worries me about that kit is that is says it's for kit's over 4". I run the Tera 2.5 spring kit and 35's.
Hey Mr. Tera flex guy, any ideas if it will work with the 2.5 spring kit?
That AEV Kit is wrong the "* Tie-Rod 'flip' via tapered insert " is not included. I spoke to AEV about it a few weeks ago. They had no idea it was on the site. I told them it was on all the sites and they needed to get it corrected. I almost ordered the kit becase of it. I would have been very pissed.
We can trade if you want!
