AEV spacer install on 2014 Rubicon Unlimited
Hi,
I just started the install of an AEV spacer kit and followed the instructions. When I drop the rear axle, the e-brake cables are tight before the spacer is loose enough to install, so I am wondering if I remove the e-brake cable bracket and then reinstall it without spacing it out if it will pull the cable housing tight at full extension.
Has anybody run into this problem? I would call AEV but of course it is the weekend
Thanks
Thanks
Hi,
Thanks
Thanks
