aFe drop-in filters - Pro Dry, Pro 5, Pro 7 ????
This is from their site;
PRO 5R
Attachment 299146
Constructed with 100% polyurethane on all four sides, this high flow, oiled OE replacement performance filter will out flow stock paper filter for improved horsepower and torque. Five layers of progressively finer mesh cotton gauze media provide maximum airflow for best performance results. Washable and reusable for multiple cleaning cycles, the tall open evenly space pleats provide excellent dust holding capacity for longer service cycle between cleanings. Integrated urethane bump seal insures tight, no leak seal over the life of the filter.
(Oiled + Out flow stock)
PRO DRY S
Attachment 299147
Constructed with 100% polyurethane on all four sides, this high flow "oil-free" OE replacement performance filter will outflow stock paper filter for improved horsepower and torque. Two layers of progressively finer mesh synthetic media provide maximum convenience and easy maintenance. Washable and reusable for multiple cleaning cycles, the tall open evenly spaced pleats provide excellent dust holding capacity for longer service cycle between cleanings. Integrated urethane bump seal insures tight, no leak seal over the life of the filter.
(Dry + Out flow stock)
Pro-GUARD 7
Attachment 299148
The "Inverted" design of this unique OE replacement filter fully utilized the space in the stock air box to provide the most filter media of any "drop-in" OE replacement filter. With seven layers of progressively finer mesh cotton gauze/synthetic media, this high flow "oiled" OE replacement performance filter provide maximum protection with highest cumulative filtration efficiency for severe duty environments. Washable and reusable for multiple cleanings, the tall open evenly spaced pleats provide excellent dust holding capacity for longer service cycle between cleanings. Integrated urethane bump seal insures tight, no leak seal over the life of the filter.
(Oiled + Out protect stock)
I hope this helps.
PRO 5R
Attachment 299146
PRO DRY S
Attachment 299147
Pro-GUARD 7
Attachment 299148
