after getting tires
do i need to get my speedo re calibrated or is it ok i put nitto terra grappler 325 60r18's on
Your speedometer will need to be recalibrated.
I bought the AEV procal when I changed tires. Its super easy to use. You just need some small fingers or a small screwdriver to flip the dip switches. I wasn't so worried about the speedo, more concerned with incorrect odometer.
Originally Posted by girom80
(Post 2381208)
How tall were you OEM tires? Your new tires are 33's so if the OEM tires were a lot shorter it would be a good idea to have the speedometer recalibrated because it and your odometer will be off. My OEM tires were 32's and when I installed 33's my speedo is off 2 mph at 65 mph, so mine isn't too bad.
i have a sahara so i think there 32 tall im pretty sure how much does it cost to have done?
With 33s I wouldn't waste the time or money I have 33s and like already said at 65 or so its only off by 2 mph not a big deal at all
ok thanks jus wanted to make sure it wasnt gonna mess anything up
I agree. Going from 32's to 33's isn't that big a deal. I'm not sure what Jeep dealers charge or if they can calibrate it for 33's. Ford dealers usually charge around $80 and they are limited to programming the computer for OEM sizes.
Originally Posted by jesse0376
(Post 2381796)
| All times are GMT -8. The time now is 02:35 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
