Air Pressure
I'm running ATX Slabs with 35 12.5/17 Nittos. What is the lowest air pressure can I run without worrying about losing the inside bead?
Typically between 10-15 psi should be a safe range....
Thanks for the reply.
With bead locks you could easily go down to 8-10psi
