Airbag didn’t go off - why?
#21
I stood it on the bumper in a steep little waterfall on Gold Bar Rim. I’ve got a JK on 33” and 2 1/2” lift. If I had a JKU or LJ or even 35” tires I would have been fine.
#22
My understanding of airbags and their associated sense/deploy mechanism is that it's purely based off accelerometer data. Don't pull enough G's and you won't get a deployment, simple as that.
Of course, I could always be wrong...
#23
You are correct. There is one accelerometer by each headlight, and one in the center console. If the vehicle has side airbags, there is an accelerometer on each B-pillar.
#24
Airbag recall on jk?
Not sure i'm in the best spot for this but recently my airbag light has been coming on and then goes away. I looked it up.. it has a recall.. anyone done this?
#25
Yes, you need to make an appointment with a dealership and they will replace the airbag. It's a common well known recall. Google Takata airbag recall for more info.
#26
Welcome to the forum. If the airbag llight is going on and off, it's usualy the clockspring causing it. Have your VIN checked at your dealer and see if your model year is covered under the recall or extended clockspring warranty.
#27
As already mentioned, best coarse of action would be call the local dealer. If a previous owner hasn't already replaced under recall, they should set you up. If they did already replace under a recall, they'll be able to tell you and you'd likely be on your own dime to figure out the issue and repair.
