Alignment after lift question
I did, I am new at this and learning as I go and appreciate your help. I turned it fully once, my pitman arm does now look angled to the right. I assuming this would be the cause for my left turn issue?
I adjusted the steering wheel so it is center. Now when I go to turn left the wheel does not seem to turn as much, would that be from rotating my turnbuckle to much on the drag link?? Turning my Jeep right the steering wheel turns fully, left after one revolution there is a lot of resistance and will not turn tighter
If that doesn't work, then I almost wonder if the drag link was adjusted the wrong direction and they actual rotated the steering wheel a full revolution. That would cause your issue (hence the comment about your pitman arm direction).
So, when you pull in straight, the pitman should be pointing forward and you r steering wheel at an angle. Then adjust.
Last option, get a stock drag link length measurement and adjust yours to that and start over.
