Alignment need after Currie Tie Rod install?
Yes.. weather you doit or a shop.
Best thing is measure your stock one when u remove it with the ends centered. Then set the currie to same length from top of joint to top of joint.
Then use the tape measure and set your toe following the project jk write up.
Its very easy.. especially with the currie rod..
Btw u need 24mm for the adjuster clamps.
sent by the rinkish with tapatalk power!
JK-Forum Founder
you don't need an alignment but you will need to set your toe-in. click on the write-up below to see how to do this...
http://project-jk.com/jeep-jk-write-...-alignment#toe
