Another Life Help Thread!
This is my first Jeep and the first vehicle I have owned that is going up in terms of suspension! So, please excuse my dumbness in all of this.
So background on my Jeep. I own an 07 JKU (non-rubicon); my goal is to put 37's on it. I don't wheel THAT often or wheel THAT hard. When I do wheel it's mainly forest trails.
Here is what I do know!
The D30 is the weak point when putting 37's on it. I figure I can "beef" it up a bit and it appears everybody is trying to get rid of D30 stuff quite often so I can pick it up repair it.
In terms of lifts from what I have gathered cam bolts and non-adjustable control arms are bad. And depending on the lift I need to be worried about DS issues.
So here is what I am considering.
Teraflex 3'' Suspension with 4 Flexarms
RC 1.25'' BL.
Fender Trim Mod or Bushwacker Flat Fenders
Teraflex Axle Sleeve and Gusset Kit
5.13 Gears
Superchips
So, I guess my questions are:
Is netting 4.25'' of lift going to clear 37's for me?
Would I be better off skipping the BL and just getting the TF 4''-4 Flexarm lift?
What would be the advantage of the 3'' over the 4'' or vise-versa?
What is the advantage of the 8 flexarm kit?
Can I upgrade to the 8 flexarm kit later?
On TF's website I don't see DS recommendations. For a 3'' lift I am assuming new DS are recommended. Could I use the stock one for a while and upgrade them later? On the 4'' lift would I need to purchase new ones right away?
Is there anything else I would need to purchase? Required or recommended?
Thanks for your help!
RC 1.25'' BL.
5.13 Gears
Superchips
RC 1.25'' BL.
5.13 Gears
Superchips
RC 1.25'' BL.
5.13 Gears
Superchips
You have a 4dr your rear shaft will last a loonng time. Your front, run it till it gives you probs.
I've been seeing a lot about the TF Front Track Bar lately something I should add? Also, I am guessing I should add a steering stabilizer?
Check this out if you already haven't
https://www.jk-forum.com/forums/show...uspension-lift.
Your plan is going along somewhat with this write up, hope it adds some advice
Thanks! I like the concept of wheel it until you break it. I already have purchased the stock parts so why not use them until they break?!?
I think you'll be fine with the 3" kit with 37s. I just installed that kit on my 4 door. I'm running 35s and it would have plenty of room for 37s. You'll be fine with 4 flex arms (I actually did front lowers and rear lowers. The kit comes with rear uppers. See if you can pay slightly more for the rear lowers). I also would get the front adj trackbar. Talk to David at Northridge. He will work with you on all of the pricing--great guy. I have zero vibration with the 3" kit.
Also, it says 3", but I think it's more like 3.5" or maybe 4". Wish I would have measured before and after.
