Any negatives with using wheel spacers
Have you guys heard of any issues with using wheel spacers/Lug pattern converters? It just seems that with all the torque at that point on the axle, that having bolts bolted to bolts would be a week link. I have had a mechanic tell me not to do it. It sounds like a lot of guys on the forum do it with no problems.
Reason for my question? I am thinking about putting the stock Rubicon 32" tires and wheels on my son's stock TJ X. I would have to find a spacer to convert the lug pattern and add a budget boost. It seems like a good way to make good use of those nice tires/wheels and help me justify replacing the ones on my Jeep? Any thoughts? Would he need to regear though?:confused: Not sure what comes on the stock 06 X. His driving is mainly to school etc., no offroad for now.
Wheel spacers are fine. I had run them on my TJ for a couple of years and without any problems before I got new wheels. As mentioned, just make sure to torque the lug nuts properly and then re-torque them again after about 50-100 miles. For extra security, red lock tite will hold things down well.
Oh, almost forgot, with 32's you should be fine without regearing
really? well I posted what I plan on getting (as far as rims) on the 'what kinda wheels you going with' poll (which noone has responded to:sad: ) and am not sure if those rims are negative or positive backspacing...Is it really bad if so? I mean would I need to get new ball bearings every 2yrs or what's the defenition of "added stress" translate into $$$??
thanks!
thanks!
thanks!
thanks!
