WOW....... this sure is a flip for me.....
Mine was easy to install.... but I did buy a smaller U bolt (2.5" I.D.) that fit much better than the 3" that came with it. Also on some of the bolt's, I went with longer one's so I could run a washer on each side. Those were minor set backs compared to you guys. Bottom line.... I would recommend it to everyone. |
Although mine was a bit troublesome to get lined up, It made my JK ride and handle much better.
It is well worth it |
I bought synergy tie rod and drag link but a buddy gave me his older model Evo bracket to use. He got the newer one which I assume is the one you are having issues with buy I'm not sure. The install of mine was easy. Had to drill one hole on the drivers side spring mount to bolt on the sway link relocater but everything else was a perfect fit. Only issue I had was my TF stabilizer is so fat that I needed to use a washer to create some space so it would mount ok.
So can I assume the bolt on one I used was changed to a newer model? The buddy hates the new one he has. |
| All times are GMT -8. The time now is 06:18 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
