Anyone with Synergy springs (particularly the 1" lift ones)?
I'm looking to get back a bit of height following the addition of a winch, bumpers, roof rack, tools, etc - I'm down about an inch on the front and the back. Synergy's 1" springs seem like the ideal way to do that without getting into bumpstop extensions, exhaust spacers, and everything that goes into a 2.5" lift, but I was looking for feedback from users on how much actual lift height they ended up with from these? Did you actually have to use wheel spacers, like Synergy says?
I'm looking to buy new shocks at the same time, and it's a little confusing as there's really no advertised shock length for between 0-1" and 1.5" and above lift heights - I assume I'd be looking at the longer ones even if I only end up with 1.25" or so.
Are you really wanting to replace the spring? Why not just through a 3/4" coil spacer up front and call it a day? $20 is a lot better than a couple hundred for springs.
