arb compressor mounting
I am not sure which bracket is the correct one to use. I want to mount it over the brake master cylinder. Which one do I order?
is this it?
the link didn't work. I will try and get a photo. It is a teraflex bracket. 1184220 is the part number.
is this it?
Which compressor? There are three different sizes.
The part number you posted indicates it works for a 'small' compressor, which I assume is their the smallest which is lockers-only. No tire inflation. And from the pics in the install guide, it mounts further forward, not to the booster.
https://teraflex.com/shop_items/56fe...d70ed4933e4efd
Now I feel like and idiot. I did not even see the install guide. I am wanting to mount the one that only works for lockers. I am looking for the bracket that goes over the brake fluid reservoir. I am planning to put in an SPOD and this bracket will take up the room where the SPOD mounts.
If someone can pass on which bracket I need, I would much appreciate it.
I used the Evo bracket to mount mine. Easy install and close to the sPod.
https://www.northridge4x4.com/part/c...ssor-mount-kit
