Sponsored by:
Sponsored by:
Auto Trans Cooler Line Repair options??
Old 01-15-2015, 06:08 AM
SoK66's Avatar
You can get those lines via Mopar Parts America for about half what that clown quoted you. 2009 Jeep Wrangler Parts - Mopar Parts for Dodge, Chrysler and Jeep: MoparPartsAmerica
Like the OP I had installed a B&M-style aux cooler some time ago, and in the process had spliced into the return line. Last year I needed to get some real estate back behind the grill to install a power steering cooler, so I switched out my auxiliary cooler for the Mopar kit. At the same time I replaced the cooler lines with the newer ones. All I'd planned to do was replace the return line, so that was what I ordered. When I got the shipment I was surprized to see they'd sent me both send & return lines as a complete assembly for the price of the return line. Installation was really easy, I just used a pick tool to remove the retainer clips. It's even easier if you use the FSM recommended Lisle special tool: 3 8" Jiffy Tite Disconnect Low Profile for Transmission Radiator Lisle 22930 | eBay
Swapping all this stuff out was really easy, the Mopar trans cooler is a piece of cake to install and swaping out the lines goes really quickly. I have an added PITA factor, as the winch has to be yanked to get the grill off.
Old 12-10-2017, 07:25 AM
sherfjeep's Avatar
Default Repost pics
Originally Posted by ronjenx
This is what I'm doing to my OEM lines. I have the parts for the flexible portion, but haven't needed to put it together, yet.
By the way, when I purchased new OEM cooler lines for this project, they were only about $30.
Is there anyway that you could repost the pictures of your repair? For some reason I cannot open them. I think it has something to do with photo bucket.
Thanks in advance.
Old 12-10-2017, 08:18 AM
ronjenx's Avatar
Thanks in advance.
Done.
Below are pictures of another way I tried. It's faster and easier.
Get some transmission hose and double clamp each end.
ID:	676359   Click image for larger version
Old 12-10-2017, 09:42 AM
sherfjeep's Avatar
Default Repair
Are those compression or flair fittings?
Thanks
Old 12-10-2017, 09:43 AM
ronjenx's Avatar
Thanks
Flair fittings.
Old 12-10-2017, 09:45 AM
sherfjeep's Avatar
Default Nice
Done.
Any problems with this setup?
Thanks
Old 12-10-2017, 10:05 AM
ronjenx's Avatar
Thanks
Which setup? The AN fittings? Or, the hose clamps?
Old 12-11-2017, 03:26 AM
chemlight_ninja's Avatar
cut the fitting with a dremel and throw a hose clamp on there. Its been working for me for two years, no weeping/seeping or drips.
Old 12-11-2017, 08:24 AM
locked&loaded JK's Avatar
Just did the lines on my 09 JK last week. Split the fittings with a dremel cut off wheel and used a flat screwdriver to pry them off. Replaced the hoses with 3/8" trans line and used Fuel injector line clamps (2 on each end)
Bottom line was the only one weeping but I replace both while I was at it.
Old 12-18-2017, 12:53 PM
sherfjeep's Avatar
Either one.
Quick Reply: Auto Trans Cooler Line Repair options??
