AXle seal help
I have a Tera44 front housing with 35 spline RCV's ... My axle seal is leaking. I need to know what axle seal I need. I called Teraflex and they said stock Mopar seal, well I pulled the axle and no way will the shaft fit thru .... Any info would be awesome, part number .....
Did you install the RCV axles or Teraflex? If they did not and sent it to you with stock or smaller axles, then maybe you forced it in...not saying you did. If Tereflex sent it with RCV axles, hell yes, they should know.
The housing was bought from Teraflex with the seals installed ... The RCV's and ARB from another shop .... I pulled the leaking seals and they are definitely larger than the factory Mopar seals ... Really weird to me that Teraflex wouldn't know the part # right of the top of their head? Its not like I have a super custom, way out there set up .......
