JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Bad balljoint? (https://www.jk-forum.com/forums/modified-jk-tech-2/bad-balljoint-117318/)
MoridinTX Feb 18, 2010 04:23 PM
Bummer, I was hope they were close to release. Hopefully after they release them the price will come down....
Originally Posted by maverick (Post 1570688)
They've been telling me the same thing since before CHRISTMAS! They say it's the engineers' fault.
maverick Feb 18, 2010 04:51 PM
I hope the get it togeher soon... I've been putting off other upgrades to my axle: sleeves, gussets, RCV axles, PSC hydraullic, truss, ACOS Pro bumpstops... waiting to do it all at the same time.
o7jk Feb 18, 2010 06:27 PM
is Moog coming out with ball joints for the JK?
Skippman Feb 19, 2010 06:17 AM
Originally Posted by ronjenx (Post 1570469)
Not to me. JK's with stock tires are also going through ball joints.
All the stress from the tires goes right to the ball joints first.
The problem seems to be the plastic in the joints can't handle the load.
They should have been bigger, or all steel, with grease fittings.
+1
Mine failed under factory Rubicon wheels and tires.
wayoflife Feb 19, 2010 06:21 AM
just catching up to this thread now. fwiw, on my orange jk, i went through ball joints in just 7500 miles and it was the source of my DW. got em replaced and all has been good :yup:
Hellbound13 Feb 19, 2010 06:26 AM
I have been through two set with 25K on the clock.
FWIW, everytime you call Dynatrac they say two weeks. I called them over a month ago and they said two weeks.
Dynatrac Feb 19, 2010 09:14 AM
Thank you for your patience. It's been hard for us too as our delivery has been postponed a few times.
Our shipment will get in next week but we will still need to inspect and assemble. If all goes as planned, and right now we're hearing all the right things, we should be able to start shipping the week of 2/28.:clap:
We understand the issue of cost. Our ball joints are a premium product designed for maximum durability. While we have a very large qty of product coming in, compared to what Moog(Federal Mogul) or some other mfg'r would do, it's still a very small amount. Also, please keep in mind that Pro Steer ball joints are made in the U.S.A. That cannot be said for most of the ball joints available on the market today.
I'll be back and provide updates as they occur.
We appreciate your support.
Scott
crazyhorse02 Feb 19, 2010 10:14 AM
Originally Posted by Northridge4x4 (Post 1570476)
That is funny right there. The cause in My opinion is that the Factory balljoints are Crap.
David
I think your right David. But I could see how the slightest thing could damage the "crappy" balljoints even faster.
tcjeep Feb 19, 2010 11:42 AM
to crazyhorse 02
I had the same problem with my 07 unl. 4 dr. with 4" lift and 37" tires, took it to a good alignment shop with the newest alignment rack we went a couple degree more on the caster angle to almost 5 degree, I think thats what it's called, anyhow it stopped the DW 40.00 bucks . :yup: tcjeep
ronjenx Feb 19, 2010 11:52 AM
Originally Posted by toad (Post 1572191)
So...IDK if this was covered or not but, how do you know when your balljoints go out? :dontknow2:
Jack the axle to get the tire off the ground, pry up and down under the tire and see if the lower ball joint has up and down play.
Grab the tire at top and bottom and wiggle it to see if the top ball joint has any side play.
The limits are:
Radial (side-to-side) movement in the upper ball joint should not exceed 0.060" (1.5mm).
Axial (up and down) movement in the lower ball joint should not exceed 0.050" (1.25mm).
This should let you know before you have handling issues.
© 2026 MH Sub I, LLC dba Internet Brands
