Basic Question
Ok I did a search and I found a lot of threads with the words Spacer and lift....
I was assuming they were the same thing...Can anybody give me a definition of what these two things are and how they differ and Why I would need either?
I realize that a lift lifts the vehicle up for more ground clearence....
and yes...all the noob flames are welcome.
A "spacer lift" is just a type of "lift". You can lift a vehicle several different ways. The simplest and cheapest is a 'spacer lift' which will put a spacer on your springs to give you a higher ride height. Other types of lifts will include shocks and springs at a minimum, and as they get better (and more expensive) will also include control arms, trackbars, etc....
Check out the FAQ section, there is a LOT of good noob reading there. Welcome to the forum!
