From a BB to Springs
Old Oct 10, 2011 | 08:42 AM
JMoss's Avatar
Default From a BB to Springs
If I have a BB installed, and want to upgrade to HD Springs, will all I need to purchase are the spring sets and then just remove the spacers when I install the springs? Is there anything else I will need that normally comes with a coil spring lift that doesn't come with a BB?
Old Oct 10, 2011 | 08:44 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Typically yes that's all that you need to do. However that depends on what brand of BB kit your running.
Old Oct 10, 2011 | 09:54 AM
JMoss's Avatar
Forgive the ignorance but what am I looking for on the brake lines?
Old Oct 10, 2011 | 09:56 AM
GreenJK07's Avatar
Once you install. Make sure they are not taught and have some play. If you don't, when you go off road and the axle drops with flex, you will rip the brake line and have no brakes....
Old Oct 10, 2011 | 10:15 AM
JMoss's Avatar
Ok thanks, I wasn't sure if I was looking for their length or if there was some kind of positioning issue I might run into..
Old Oct 10, 2011 | 10:20 AM
w squared's Avatar
If you're increasing in overall lift height, you may find that your steering geometry has changed - and that may require things like adjustable track bars, adjustable control arms, or different sway bar links. The modified tech FAQ has a ton of very useful information to provide some guidance, and if you have specific questions there are lots of folks here to help you out.
