Best bolt in roll cage on the market
Not to derail the basis of this thread, but I'd like to suggest reconsidering the Synergy weld in cage. Much stronger, far safer, and better designed than any bolt in cage. If you are going to the hassle of installing a cage, why go half-a##? If you call at the right time, you can get the full cage for $750 delivered.
Do a little searching and you will have no trouble finding a TIG welder looking for some work. Get the cage put together and then you're really not looking at much for the welding. All in, maybe a $1000 (cage + welding) for a full weld in cage that is tied to the frame.
^ What he said.
I have 3 wheeling buddies that have the rockhard cages and they love them. I've installed a PSC cage for a buddy and it was a pain in the a$$ but he's happy with it overall. There a pictures online with both cages after a roll over and they've all done their job. The sport cages will protect you and do work well. After seeing both cages and some heavy thinking I decided to go with a custom cage. I plan on keeping my jeep until the wheels falls off and wanted to do the cage once.
Custom - Based off of the Synergy 1st Gen cage
PSC Cage
PSC Cage
I run the Rock Hard and there front harness bar they are both beefy and very well made but I do wish the sport cage went to the floor, but the install was clean and no issues. If you have the time and the cash deffinitley go with weld like the synergy. But with a few tools and a drill bit you can bolt the Rock Hard up in a day!
What about Smitty built?
I know this is a older thread. Im Johnny come late. No one mentioned Smittybilt SRC Cage. Good, Bad, OMG kick this guy out of the club? It looks very similar to the Rockhard kit for construction.
Smittybilt is a very 'economy' brand. It would be good if you'd just like to say you have a cage. Would I trust my life to it over one of the other brands? No. Absolutely not. I've had a smitty bumper and while it is a stout unit (anyone can stack metal and bedline it), it isn't braced well and isn't as good functionally as it should be.
I'll echo what's going around here and add another option now. I've got the Rock Hard cage in mine, along with the weld in C pillar. That area is a ton of span, so every little bit helps. I've had to move mine around a few times and it's a tight fit to get the components in and out and lined back up. It's a solid piece and I have no complaints and I run mine all over the place. It's stout and doesn't make any noise going down the road or down the trail. Not going to the floor is the only "weak link" I could potentially see. Tying into the factory bar between the windshield frame and B pillar, is another potential shortcoming, but not a real knock. Still beats the hell out of the factory.
I put a PSC cage in my buddy's JKUR and it was a pain in the ass. The connectors are solid and very tight fitting. If you have the cage powdercoated, make sure and clean up all the connections or you'll fight it forever. Anti-seize is also your friend with those connectors. The front does go all the way to the floor and bolt in. The supplied bolts were a little long and made for some knocking in certain conditions as they hit the frame supports. Overall, nice solid cage.
Evo recently introduced one that I've not had any experience with, but it's a good looking cage and seems to be right around the same price point, plus it's chromoly versus mild steel.
https://www.offroadevolution.com/pro...ge-w-rear-bar/
Go RockHard 4x4 and don't look back. I got it because of the non-existent "A" pillars on the JKUR.
