Best Gear Upgrade for 6 speed?
Old May 16, 2011 | 02:01 PM
Harve10's Avatar
Default Best Gear Upgrade for 6 speed?
All,
I know most are probably sick of re-gear questions by now, but I need some advice. What gears would be best for a 2DR 6 speed running 35s? Jeep is my DD and I plan on adding the Ripp SC in a few months. Appreciate the help!
Old May 16, 2011 | 03:11 PM
nthinuf's Avatar
4.56 will get you back to a 'stock-like' ratio, and should be a good match with the extra power from a S/C. (if you can find them?)
4.88's are very popular for manuals on 35's, and folks that don't do a lot of high speed freeway driving may go up to 5.13's. I have never run a manual or a s/c, but my thought is that 4.56's may be a better choice for you.
Ripp is a sponsor, so it wouldn't be a bad idea to just send them a message to get their input.
Old May 16, 2011 | 03:15 PM
Mad-Hatter's Avatar
my 4.56s go in this week so I'll let you know
Old May 16, 2011 | 03:18 PM
JKmudslinger09's Avatar
I'd go with 4.88's. It's going to return a lot of the lost power when you bumped up tire sizes. What are you running right now for gearing?
Old May 16, 2011 | 03:24 PM
wayoflife's Avatar
JK-Forum Founder
only on paper. the reality of it is, 4.88's will provide a much better 'stock like' feel and 5.13 will give you a boost in power. i would NOT recommend 4.56 for 35's. trust me, i have test driven all 3 setups.
Old May 16, 2011 | 03:50 PM
BKGM Jeepers's Avatar
I ran 4.88's in my TJ with 37's. I went with 5.13's in my JKU with 37s. I now run 38's with the same ratio and am quite happy. I have a 6-speed.
Old May 16, 2011 | 05:21 PM
genesbro's Avatar
Since you are going to install a super charger I would go with the 4.56s. If you are not sure about going with the super charger then you would need lower gears.
Old May 16, 2011 | 05:27 PM
Mad-Hatter's Avatar
I figure it all depends on your application/usage. Just know what you get with each option and do your homework. For me, 4.56s were the ticket with my 6 speed. With 35's that measure 33.75, a swapped in 4:1 T-Case, a dana 30 up front that I want to keep the pinion as large as possible for durability, and significant highway time looming on the horizon...it made the most sense for me.
Old May 16, 2011 | 05:53 PM
genesbro's Avatar
I have the 3.73s and can use 6th most of the time. I figure if I had the 44s and 4.10s like the Rubis have it would be about right. Like you I don't want to have that little tiny pinion. I don't mind using the gears to get my rpms where they need to be on the road, thats why there is more than one gear in the tranny anyway. I know lots of people these days like to get it in top gear and leave it there it seems.
Old May 16, 2011 | 06:03 PM
Mad-Hatter's Avatar
Yeah, I agree. Until now, I just used a lower gear for the highway when needed. But where I'm moving soon...the hills are bad enough to risk it with the smaller pinion. Like I was saying, my applicationed changed and you just have to weigh all that and use your nugget OP.
