Originally Posted by jordy
(Post 4340842)
I've got a 3 gallon tank under the Jeep that will more than run the lockers all day long on a single fill up. I kick my compressor on, let it build pressure and shutoff automatically, then I kill the power to it. I've got a bunch of plumbing as I have air chucks at the front and rear, so I lose some via inherent leaks. Every few hours I might kick it on if I think about it and it runs for 30 seconds and shuts off again. I could likely go all day without hearing it, but it's not a big deal. The amount of air that is released when the solenoids open and unlock the lockers is probably half a breath, if that.
Originally Posted by DEJK2012
(Post 4340832)
So if i have it mounted in side the cab, say under my seat, will i be having to scream at my passenger because its always kicking on to fill the tanks? t
I'd personally not even think about air tools. |
(Post 4340845)
That's ironic as here you are talking out your ass about a product you have no experience with other than tire kicking and passing because of cost. Me? I have the ARB compressor that the OP had a question about. I have ARB lockers front and rear. You're still running metric tires. Come back and talk about something you know about as you've done nothing to help resolve the original question asked. That's pathetic. You not get enough attention at home? :thumbsup:
(Post 4340846)
Where did you mount your tank? I was thinking about cutting off the recessed storage think above where the stock muffler goes and welding in a flat panel and having the tanks mount there. I have an old "portable" compressor that the compressor died on and was going to rob the two tanks it has on it, they are small enough to fit between the frame rails. just havent figured out of mounting them there will get them ripped off when i come off ledges. (im in a jk so space is tight)
The rear storage area is a good plan, but I'd consider keeping the tanks inside if corrosion is an issue. Make sure you keep the pop off valve, or add one if it doesn't have one, so you don't create a pipe bomb.
Originally Posted by resharp001
(Post 4340847)
Assuming you don't have a leak in a line, that compressor gonna kick on and takes but a few seconds to fill the line and engage the locker. It's not going to sit there and run constantly. When filling up tires, you and your passengers typically aren't sitting in the cab while it's running, but even then, it's not like a freight train passing by.
I'd personally not even think about air tools. I've been thinking about this situation more and more in regards to the air tools. I've never had to deal with them on the trail, knocking on wood, but you'd be hard pressed to find any compressor out there that would run a 1/2" impact hard for much time without a big tank behind it. I've run them off air tanks on heavy equipment before to change out cutting edges and it's the same principle. Build air, run the gun, build air, run the gun. Pretty tedious operation, but it can be done. Saw a few guys doing trail repairs in Moab with the battery powered impacts, and that seems like a more viable alternative. Milwaukee and Dewalt seemed to be the tools of choice. Personally, I'm a big fan of Dewalt and own a ton of it, but not a battery powered impact. I'm sure Harbor Freight makes some for the budget conscious. If someone was set on running air tools, a CO2 tank from Powertank or the like would cover that base well. I use mine pretty much exclusively to air up as 40's take a while, even with the dual compressor, and it is handy should your tank on your kegerator run out unexpectedly. OP could downsize the compressor to the single ARB and add some battery powered tools and cover all the bases, but airing up would take a while longer. It's a choice about which one you spend more time doing I suppose, airing up tires or running tools. Hopefully that helped clear things up a bit. |
(Post 4340847)
I'd personally not even think about air tools. Noise concerns aside, the main reasons I preferred not to mount an air compressor inside the interior was due to limited space in regards to compressor heat concerns and carpet fibers. We all know these compressors run hot. When you mount it under a seat like many tend to do, there is a very limited air circulation to help assist in cooling the compressor. Plus, it's often mounted on top of the carpeting, so you might as well be wrapping it with a blanket. So I worked in the designs/development of audio amplifiers, which also tend to get hot where mounting the amp under a seat was often considered. There were definitely additional challenges that needed to be tested and designed around to ensure the amp didn't over heat, which often resulted in adding cooling fans and additional heat sink to the amp design. Additionally, we found that carpet fibers and people spilling drinks on them in those locations to be very problematic. The fans would pull in carpet fibers, getting those fibers into the electronics, adding a risk of fire, damaging the electronics and also blocking the air flow passages. What does an air compressor do? It sucks air in one side and forces it out the other, thus you have the same type of concerns with carpet fibers and heat. No one ever comes on the forums and tells you how great their interior mounting of their air compressor was when it over heats or starts catching the interior of your Jeep on fire, or their kid spilled their McDonald's coke on it. ;) |
(Post 4340845)
Cool it fellas.
Originally Posted by Rednroll
(Post 4340854)
In regards to tools, if you're really being honest with yourself, what are you gonna do with a compressor tank set up on a trail that is going to make life exponentially easier than having the proper hand tools available. More hassle than it's worth really.......ALTHOUGH, looks cool to people cruising by as you work on yo broke ass rig. :rotflmao2: For real use of tools, you need CO2 IMO.....but even then your lugging CO2 around, extra tools, etc. I just came to terms that almost all trail repairs are performed just fine with good hand tools. |
(Post 4340858)
^^^ This. OBA is great for airing tires and running lockers... the rest, I carry hand tools for. Though, I will admit I keep looking at those 1/2 battery operated torque wrenches... |
Originally Posted by GIROGecko
(Post 4340856)
i ignore most everything rednroll posts. he likes to do a lot posting without any actual knowledge of what he's talking about.
