JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   brake line extenders (https://www.jk-forum.com/forums/modified-jk-tech-2/brake-line-extenders-184719/)
decan1 Jul 2, 2011 08:45 AM
I am installing a RC 2.5" spacer lift and am noticing that my brake line do no "flex" enough to install the brake line extenders that are included witht the kit. Do I really need them? Any suggestions or idea`s
TomOH Jul 2, 2011 09:11 AM
I would say yes. If the brake line gets over flexed it could bend or worse yet snap, if the extender line is to long cut it to length then put the end back on and re-flair it, should only take a minute or two to do, wort the time for your & anyone else's safety in & around your Jeep. Hope this helps.
decan1 Jul 2, 2011 09:51 AM
Sway bars are still attached....Don`t do heavy offroading.....can`t cut the extenders because their thicker steel...... any thoughts
jeep2007 Jul 2, 2011 09:54 AM
For the front lines you will need to getly bend ten downward for the extensionsto work. Same for therear. Just bend them slowly.
Scott08X Jul 2, 2011 10:48 AM
if they were included I would install them
mkjeep Jul 2, 2011 11:16 AM
Unclip the hardline from the frame, grab firmly with hands as close as possible and bend sloooowly a little at a time working your way down the line abit.
decan1 Jul 2, 2011 12:54 PM
ok.....bend very slooowly. i will try tomorrow and update the post. Though I noticed that there seems to be enough slack for the rear lines. Wish me luck.
jeep2007 Jul 2, 2011 07:18 PM
You do that and i'll use spell check. :) MK...nice avatar!
decan1 Jul 3, 2011 04:11 AM
That's ok.....I started off the thread with spelling mistakes! Makes sense that others would follow suit
decan1 Jul 3, 2011 07:16 AM
Ok. All done! I know the above the extender the metal lines aren't supposed to move. It doesn't look pretty but it works. Thanks for the advise guys. I will post pics later
© 2026 MH Sub I, LLC dba Internet Brands
