Brawler Lite Tube Gussets Modifications for Power Plant
Apparently there is a slight modification required to run a Warn Power Plant winch on a Poison Spyder Brawler Lite bumper w/ DOM Tube Gussets. From what I've read, the winch monting holes in the bumper have to be moved to the rear slightly. Does anyone know how far the winch mounting holes are moved rearward? Also, are there any other issues with using a Power Plant on the Brawler Lite w/tube gussets?
"On Brawler Lites with Brawler Bar with DOM tube gussets, some slight modifications are needed to fit the Power Plant."
Thanks for any help,
NIB
NIB
Brawler bumper withe PowerPlant winch
NIB
NIB
JK Brawler Lite Front Bumper - Brawler Bar - Plate Gussets | Jeep Wrangler JK Front Bumpers | Poison Spyder Customs
KG6SLC aka Eugene
Thanks, I will give them a call Monday. I just figured someone had been down this road before and could post a quick answer. I guess most people prefer the plate gusseted over the dom tube gusseted. One way or another, I have to make it work because the bumper is setting in my garage now.
Thanks,
NIB
Thanks,
NIB
Looks like it'll fit, might as well try and see.
I'm running the Crawler concepts front skinny bumper and squeezed a Power Plant on there. I used a few washers on one side between the winch and the bumper.
Just in case anyone else would like to know the small mod required to mount a Warn Powerplant winch on a Poison Spyder Brawler Lite Front Bumper w/DOM Tube Gussets, per PS Tech Support, the winch mounting holes need to be elongated about 1/2" to the right (I believe he said right). Otherwise the winch will make contact with one of the tube gussets. The bumper arrived from Northridge 2 days after ordering and it looks great.
