Budget Boost
Originally Posted by mark jk
Just looked 14ab and 55aa is that the numbers that you are talking about? If so the 19/60 would it lift it some?
All i need is the coils ? Will they work ok on all of the stock parts that i have if it lifts me up 2" ?
Yes.... If you go with a BB you will need the rear brake line relocater and shock extensions, but most kits should come with that. A lot of people actually run this setup because it's a cheap mod and improves the ride. You will be surprised on the height you gain from such a simple/cheap mod
I have a Rubicon, so I had stiff springs to begin with. 15/56 I believe. I ended up switching to 18/58s, gained all the height I lost from Mopar bumpers front and back, rear tire carrier, Warn 9.5 ti winch and Mopar front skid (the steel one) + 1/4 inch, I believe.
I don't notice any harsher ride, but I'm still comparing it to my '92 YJ and I think my JK rides like a luxury car compared to it.
If i run my stock 17" what size tire can i run ? And what wheel spacer would i need ? I would like a good AT tire.
What if i just do the Rubicon springs and on kit. Will all the stock parts work ? Or do i need relocater and things ?
