Sponsored by:
Sponsored by:
What air pressure do you run in your 35"s?
Old 11-21-2011, 12:56 PM
Rick in Colorado's Avatar
Default What air pressure do you run in your 35"s?
3.5" AEV lift kit on a 2-dr 2012 JK. Dave at AEV suggests 28psi. Discount Tire says 35psi.
Old 11-21-2011, 01:09 PM
4WHLN's Avatar
Im running 28 in my grapplers.
Do a search. There has been a couple threads on this topic.
Old 11-21-2011, 01:14 PM
dinojeep's Avatar
From the FAQs:
Q: On the road, what PSI should I be running in my tires?
A: For optimal comfort and even tire wear. you should not run the recommended PSI listed on the sidewalls of your tires. Typically this will be way too much. On average for a 33" tire, I would recommend that you run your tires at approximately 28-30 PSI. For a 35" tire, I would recommend running approximately 26-28 PSI. For a 37" tire, I would recommend approximately 24-26 PSI.
I run my 35s at 29-30 psi. 35 psi would be too much.
Old 11-21-2011, 01:20 PM
ChryslerChris's Avatar
28 psi. It's what I run. 35 will beat you up. The tire places think all vehicles are Honda civics.
Old 11-21-2011, 01:22 PM
Hook-Em's Avatar
I'm running 32-35 psi in my 315/70R17's and love the ride and handling characteristics.
Old 11-21-2011, 01:27 PM
Ryan0260's Avatar
Running 30 in mine
Old 11-21-2011, 01:47 PM
tslewisz's Avatar
28 psi with 8" wheels and 315's
Old 11-21-2011, 02:21 PM
photographix33's Avatar
38 on the street with MT Baja Claw 35's was suggested by MT Rep.
Old 11-21-2011, 02:31 PM
Friday2322's Avatar
28 here seems to be about right on my 35's, the tire store put in 40 when they mounted my tires and it rode terrible.
Old 11-21-2011, 02:41 PM
tenmile's Avatar
26 PSI on the street, 315/75/16. 28+ starts to ride a bit too rough for our crappy roads.
Quick Reply: What air pressure do you run in your 35"s?
