Budget tailgate fix ordered. Mor/Ryde hinges and MBRP re-inforcment.
#341
I have installed mine almost a year ago and the rubber stopper/bumper pieces that are on the end are falling appart now. Is there anything that should be done tonprevent overextension of the hinge?
#342
I never had the rubber pieces, instead added a stainless washer under the head of one of the hinge bolts to act as a stop.
#343
There is an optional additional stop you can get from MORryde, it's included with the tailgate reinforcement kit but not with the hinges; it's needed with the reinforcement kit but not usually with just the hinges. If you want one of the optional stops you can ask MORryde to send you one, it looks like this:
But as karls10jk said, a washer under one of the screw heads on the body side of the hinge will also serve as a stop if you want to restrict the opening of the tailgate a bit more.
#345
- HD tailgate hinges
- Tailgate Reinforcement, which adds additional strength to the tailgate to carry heavy spares and gear
- HD spare carrier, which replaces the factory spare carrier. It's stronger, and positions the spare higher so larger spares can clear the factory bumper.
- Other options are also available, such as a bracket for carrying a HiLift or a Rotopax container on the hinges.
If you mean to ask why the optional stop isn't included with just the hinges, it isn't necessary - the hinges are designed so they stop at an appropriate point, no extra stop is necessary. The stop is required with the tailgate reinforcement because the reinforcement slightly changes the geometry of the swing of the tailgate as it opens and without the stop the tailgate could open too far, stressing the factory tailgate stay rod that's standard on later models. If someone wants their tailgate to stop at roughly 90 degrees rather than opening a little further, and they have just the hinges installed, they can install the optional stop (or a washer as described earlier); MORryde can be contacted about getting the optional stop.
In this photo the HD hinges, tailgate reinforcement and HD spare carrier are installed:
In this photo only the hinges are installed:
#346
Jeff, is Ryan still the POC over at MorRyde? I installed the washer as a stop and it has been working but now it's started to munch at the end of the hinge and is going further than I'd like it to go.
#347
The best stop for the hinges is the MORryde stop I posted about here: https://www.jk-forum.com/forums/modi...5/#post4328461, you can get them from MORryde. They are included with the full tailgate reinforcement kit but not with the standalone hinges since they're most often not needed with just the hinges alone.
The hinges on my JKU are from MORryde's very first production run, they've been on there over 3 1/2 years with the reinforcement and stop and they still look great - so good that when MORryde borrowed my Jeep last week for the SEMA Show, we decided that the hinges looked so good they'd have the Jeep in the show with the original 3 1/2 year old hinges.
These are few shots from the SEMA Show, MORryde was showing the hinges and tailgate reinforcement as well as the new Overland Rack that mounts to the tailgate (scheduled for release this month) and the Trail Kitchen.
Not bad for a daily driver with 135,000 miles on it .
#348
That's right, Austin took care of me last time. Thank you, I'll be contacting him as I've got all 3 tailgate pieces as well as the jack mount. I saw the rack and the trail kitchen on their site this morning, the rack is on the wish list if I ever get to venture west to Moab.
#349
