Bump stop extensions
Old Mar 25, 2016 | 01:43 PM
4wheels4life's Avatar
Default Bump stop extensions
Have not had to deal with this before so a basic question. I need to add a bump stop extension onto my JK so the passenger side axle control arm mount will not hit my a/c compressor (LS install with gm accessories). Do I need to add the same amount to both sides or just the passenger side?
Old Mar 25, 2016 | 01:57 PM
Fusion 4x4's Avatar
Former Vendor
Technically, you could do one side, but keep things even and do both. You'd likely have to use more if only doing one side as the angle to the other will bring things a little closer.
You can easily move the control arm mount a little as well. Or fab a different style mount that has more clearance.
Old Mar 25, 2016 | 04:09 PM
Yeah equal is always better thank you. Ill just do both sides and be done with it.
