Bumpstop maxing on one side only?
Check your bumbstops if you haven't already. I was having something similar happen after installing new rear bumbstops. Turns out I had positioned one backwards and it was sticking out towards the rear a bit and snagging on the frame side track bar mount.
maxing out on even the smallest bump! even without shocks this should not be happening.the shock may be bad but even if you fix it something is not right.either your bump stops are too big or you are running a lift that is too small. off road this will be a pretty bad problem.you never stated what size tire and lift you are running...
