C or D rated 35??
Looking for a 35 12.50 18 or 325/65/18 all terrains that are other than E rated. Currently have trail grapplers that are E rated and they ride like they are filled with concrete.
Unfortunately I'm may need to ditch the 18s to accomplish this.
Thanks.
Thanks.
My E rated Trail Grapplers ride smooth as glass, and I'm running 18"x9" rims myself. I like them because they only weigh around 71-72 pounds per tire.
The amount of plies a tire has is solely for the purpose of carrying more weight. It doesnt make it more resistant to punctures and it doesn't make it wear slower. A class C tire is 6-ply and for every letter up two plies are added. (ex. C=6, D=8, E=10 etc.) That being said the amount of plies only pertains to the actual part of the tire hitting asphalt. Not the sidewalls.
That being said...there are several tire companies that make the same tire with different ply ratings. (ex. 285/70r17 BFG All Terrain) The tire is made in both C(6) and E(10) ply ratings.
There are tires, however, with 3-ply sidewalls. The BFG AT and YOKOHAMA ATS being two examples. Most will only be 2-ply.
For a jeep, being as light as it is STOCK, I wouldn't do more than a 6-ply tire or else u will not only have a stiffer ride BUT u lose traction because a 10-ply tire is made for the weight of a 3/4 or 1 ton vehicle such as the heavy duty pickups. That being said...if u do plan on doing alot of mods to the jeep u may want to consider goin ahead w a higher load index.
Make a long story short...if you are going to keep the mods minimal I would go w a C-class tire. If u gonna out several heavy mods and will need to carry more load...spend the extra dough and get a tire capable of carrying more weight. The only difference bw a 6-ply and a 10-ply is load index, not tread-ware and not puncture resistance.
Thanks.
Thanks.
