C Gussets
I got the TeraFlex gussets. If you have a friend that can weld then you're good. Weld a little and make sure the ball joints don't get too hot. A wet rag or three helps this. A friend welded mine and didn't take nearly as long as expected. He was persistent on keeping wet rags on the ball joints. They were $40 or so and no install charge, so it was cheap insurance if I need it.
It is one end of the front axle. The tire/brakes would be just to the left in the first couple of pics.
The first pic is a stock 'C' - it is facing backwards in that pic, but you can see why they are called c's. (you can also see the upper balljoint on top of the C, and the axleshaft coming out right in the middle of the upper/lower c's.)
The second pic shows the upper gusset placed on top of the upper c.
The third pic shows both the upper and lower gussets placed on top of the upper and lower c's.
The fourth pic shows the upper and lower gussets for both ends of the axle. (lower gussets on top, upper gussets on the bottom of the pic).
The fifth pic is a single lower gusset that has been pre-fitted to a c, and then welded.
The 6th pic is a close-up of the lower c gusset welded to the lower c. (and you can kinda see the upper gusset above it.)
The seventh pic is just another angle of the welded lower gusset.
Clear as mud, huh...
Another note of caution is that welding is kinda hot. If you notice the placement of the upper and lower balljoints, they are real close to where those upper and lower gussets are being welded on, and the grease inside the bj's is very susceptible to getting fried. Extra care should be taken to keep them cool if they are not removed during the install.
When doing the gussets it is recommended that you also change out your ball joints (you dont have to though) BUT if keeping factory you need to tell welder to take their time and do a little at a time so you dont heat up the plastic inside the factory ball joint. After markets are metal and way more durable btw
The stock C's are weak. People have bent these with stock tires . It's not if you will bend them but when. Once bent , you can't unbend them. Your camber will be outta spec and as nuthinuf said you'll need adjustable ball joints. I'd be willing to bet there are alot of people running with bent C's on here that don't even know it. They are cheap insurance for a very common prob.
