Calibrating speedometer - bigger tires - superchips flashcal
Hey all, I recently installed Goodyear Duratracs (285/70/17) on the stock sport wheels and bought a flashcal to correct the speedometer. I followed the instructions and measured from the ground to the top of the tire and it came out to about 32". Uploaded the tire size into the jeep and the speedometer seems to be off a bit. It is dead on up to about 35-40 mph, but when you hit 50-60 mph the speedometer reads about 2mph faster than the GPS and is more noticeable at 70 (2-3mph). Any tips on getting the speedometer corrected from users that have the flashcal? Thanks :beer:
Try and make the size .1 bigger. If your speed is reading too fast your computer is reading your tire as being smaller than it is.
You can try as above stated or just leave it go. A few miles an hour is no big deal.
Sent from my iPhone using Tapatalk . Rich |
Originally Posted by Ryan0260
(Post 4005939)
Try and make the size .1 bigger. If your speed is reading too fast it is your computer is reading your tire as being smaller than it is.
I had the same issue....with my 33's, I had to adjust my SuperChips to 31.50 to get my speedo to be accurate. It being off really effects the shift points.
I added 285 70 R17s duratracs ( went from stock Sahara 18" wheels and tires ) and have not needed to adjust anything. Speedo matches GPS dead on. I am assuming the GPS is reading speed from Gps and not tied to the speedometer.
Originally Posted by jeepfan4life
(Post 4017142)
[QUOTE="rob_engineer;4017188"] Aren't those tires 11.5 inches wide? Did you need to do anything to accommodate that size tire?[/QUOTE
I went with the AEV pintlers so there is enough back spacing as part of the rim. (I think). I also added a 2" spacer lift. The tires do stick out beyond the stock fenders a bit. I wonder if anyone else with this setup has speedometer issues. ? |
(Post 4017142)
| All times are GMT -8. The time now is 03:08 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
