I have an 07 that just had some similar behavior. After changing the cam position sensor and seeing the same issue repeat, I took it to my local shop and they noticed my spark plug wires were toast. Replaced wires and plugs, and so far no codes.
circuit
Originally Posted by jtphoto JK
(Post 4271573)
Maybe there is a problem with the engine and the sensor is doing its job telling you something is wrong? Just seems strange it would go into limp mode for simply a bad sensor.
2013 Jeep Wrangler Unlimited Sahara
I've noticed the problem only when the weather is warm or hot and the motor has run awhile.
I've replaced all the sensors and the issue still exists. My mechanic believes it may be an issue with the computer, which would be about $600 to replace. And that's no guarantee to fix it. I'm going to have to try what was said about the plug and taping it up. |
I know this thread is old but did you ever find a fix. I’m having the exact same issue right now and trying to find a fix without throwing parts at it. |
Yep!
cam phasers. Replaced them in January and havent had the problem ever since |
Camshaft
Anyone fixed this problem?
Possible solution.I had the same issue.
I have a 2007. I had the same issue. It only seemed to happen when the engine heated up. Was always fine when first starting out. Then check engine light, traction control light and limp mode. Tried some basic trouble shooting: changed the spark plugs,new cam sensor, new crank sensor, new battery, NOTHING worked. Finally found a rough looking EGR. Unplugged it and drove around for a day or so with no issues. Replace the EGR and have had no issues since. Since then I have put about 100 miles on the Jeep and so far so good. Hope this helps! I have also read that is could be an issue with the PCV. Good luck!
What is an EGR
Originally Posted by janellenicole88
(Post 4325721)
Originally Posted by justinstoffregen
(Post 4332073)
What's an EGR please?
Originally Posted by JBri
(Post 4325434)
