Sponsored by:
Sponsored by:
Can a Rubi front Tru-Lok be installed in a rear X D44 axle housing and work?
Old 06-16-2017, 11:15 AM
bkelly's Avatar
Default Can a Rubi front Tru-Lok be installed in a rear X D44 axle housing and work?
A buddy of mine gave me a front Tru-Lok from his Rubi ...... Question is can I install it in my JK X rear diff and it work (after I figure out how to wire it up)?
Old 06-16-2017, 11:25 AM
BoraBora's Avatar
The factory e-locker?
I think so. Front is 30 spline on the Rubi, and the Sport rear is 30 spline. So theoretically yeah, should work fine.
Old 06-16-2017, 11:28 AM
aermotor's Avatar
Pretty sure the Rubicon rears are 32 spline.
Old 06-16-2017, 11:49 AM
nthinuf's Avatar
The center sections of the housings are different. While the front rubi and rear non-rubi both use 30 spline shafts, the rear non-rubi housing is designed for any 'standard' locker, and the rubi housings are designed specifically to fit that factory locker. (If you look at any of the aftermarket d44's, they will state whether the particular housing is for standard lockers, or a 'rubi 44 e-locker'.
Way back when, I remember a detailed post from one guy that did a bunch of custom work and got a rubi locker to function in a non-rubi housing --> but he said it wasn't worth the time and effort. If he were to do it again, he'd just buy a arb instead.
Old 06-16-2017, 12:02 PM
MacRubi2's Avatar
Also the rear axle shafts are different lengths on the Rubicon compared to the non Rubicon shafts
Old 06-16-2017, 12:10 PM
bkelly's Avatar
Just found that other thread ...... I might have to change my plans ......
Old 06-16-2017, 02:29 PM
Digger 5's Avatar
Yes, it can bolt in but will require special axle shafts. Stock Sport 30 spline shafts will not work. The differential centerline is different than a conventional diff.
Old 06-16-2017, 02:58 PM
ronjenx's Avatar
You don't mention the difference in the carrier bearings.
Old 06-16-2017, 03:02 PM
Digger 5's Avatar
My mistake- I missed the X-housing 44 rear.- The bearings are the same if bolted into a Rubi housing but there is no conversion bearing to allow the front or rear electric locker to fit in the X or Sport rear housing.
Quick Reply: Can a Rubi front Tru-Lok be installed in a rear X D44 axle housing and work?
