check engine light on after lift install???
ok, i just got finished putting a 3.25" lift on my 2 door jk. and after i plug the procal in to program in the tire size my check engine light is on... the one that looks like the transmission. it just stays on. i havent driven it very much since yesterday....
has this happened to anyone else? it drives just fine. i just dont like that light being on.
Check engine comes on any time you unplug something.
Mine came on after we looked for a ignition keyed power source and unplugged the harness for a few minutes .
It will reset after starting the engine a few times if everything is ok (which it probably is)
yes but i need to recenter it again. i am going to get a local shop to check over the install to mainly make sure the angles are correct. i am stressing myself out over them... i will recenter the wheel again after i get it aligned and checked over.
