coil spacer sag
Old Mar 11, 2009 | 04:16 PM
tboth09's Avatar
Default coil spacer sag
i was looking at the 2.5in rough country coil spacer lift and was thinking or buying and using it with the rubicon springs and shocks with extensions. but then i was wondering if the srpings would sag if i put bumpers on. i know they do with a normal coil lift but i didnt know if it would with the spacer lift. i would assume there would still be sage with this lift becuase there are still springs. is this correct?
Old Mar 11, 2009 | 04:27 PM
nangulator's Avatar
You will get more sag with stock springs than with most lift springs (heavier spring rate on most of the coil lifts)
Old Mar 11, 2009 | 05:44 PM
Littlejon's Avatar
You will get some sag with a bumper, but if you get some stock TJ springs from a 4.0 engine it will fix your sag and take you back to stock. Also rather than just adding a spacer the higher spring weight will help with the handling with the added weight since you won't be overcompressing the stock one at all times. I did this after adding a bumper and I got 1" of lift, and am back to where I was stock, and now am thinking about a budget boost until I can afford a nicer lift.
