Coming to my jk this weeked CORE 44
#71
CORE 44 Update
At the 500 mile marker of my new CORE 44's (front & back) I took my Jeep into the garage to change the diff fluids and check everything. There was some minor shavings in the diff oil which were captured by magnetic plugs. The rear diff was leaking from the front where the driveshaft bolts to the diff. For what I spent, I would think that diff would be bone dry! At first the mechanic & I thought it might have been due to a possible overfill by putting the full 2.2 quarts of diff fluid and 6 oz. of additive. The mechanic & I decided to put only 2 quarts plus 6 oz. of additive. After a couple of days, it was still leaking. I called 4WD where I bought the CORE 44's and sent the requested information & pictures. They contacted G2 and now 4WD sent a front pinion seal, which should be here in a couple days. While I appreciate 4wd sending replacement parts, I am a bit torqued that I have to either install the seal myself or pay to have it installed. I am somewhat mechanically inclined but I don’t have some of the tools to complete a front pinion seal swap. I asked 4WD if this was something they would pay for and it’s basically on me. Shouldn’t G2 or 4WD pay for the install? Hopefully, the seal will fix my problem. I have been hesitant to go out & try my new axles due to the break in period and now this leak. Once I get this fixed, I plan to hit the woods. I’ll keep you all posted.
#72
At the 500 mile marker of my new CORE 44's (front & back) I took my Jeep into the garage to change the diff fluids and check everything. There was some minor shavings in the diff oil which were captured by magnetic plugs. The rear diff was leaking from the front where the driveshaft bolts to the diff. For what I spent, I would think that diff would be bone dry! At first the mechanic & I thought it might have been due to a possible overfill by putting the full 2.2 quarts of diff fluid and 6 oz. of additive. The mechanic & I decided to put only 2 quarts plus 6 oz. of additive. After a couple of days, it was still leaking. I called 4WD where I bought the CORE 44's and sent the requested information & pictures. They contacted G2 and now 4WD sent a front pinion seal, which should be here in a couple days. While I appreciate 4wd sending replacement parts, I am a bit torqued that I have to either install the seal myself or pay to have it installed. I am somewhat mechanically inclined but I dont have some of the tools to complete a front pinion seal swap. I asked 4WD if this was something they would pay for and its basically on me. Shouldnt G2 or 4WD pay for the install? Hopefully, the seal will fix my problem. I have been hesitant to go out & try my new axles due to the break in period and now this leak. Once I get this fixed, I plan to hit the woods. Ill keep you all posted.
#74
Yup
#75
#76
I did manage to rip the wires out of my stock rear rubicon axle...the ones going into the indicator switch... too much snow and ice pilled up under there and the wires pulled out of the switch! It must be a jeep thing...
#78
Front Pinion Seal on Rear Diff Replaced
It's been a little more than a week now, since I had the front pinion seal on my rear diff replaced, and I am happy to report: ALL IS BONE DRY!! I am looking forward to getting out and hitting some trails soon to give these behemoth axles a thorough testing!
#80
Another update on the Core 44
I decided I had been in enough snow, water, and mud that I should change out the fluid a couple weeks ago. The thought I had was that there might be some shavings in the diff. I dumped the break-in oil after 400 miles, but still assumed that there would be some metal flakes in the oil. The oil still looked new! Color was good, no metal, no sign of any wear on the locker. All works fine...
The pinion seal has not leaked in a long time now... had a slight leak at first but it never has re-opened.
Nothings is bent, ball joints and all are holding up well!
Now comes winter again. The Axle has a lot of miles on it now... Locker still works really well, I have not had it "let go" under lock yet, as some said they had an issue with that. So far no problems!
