Sponsored by:
Sponsored by:
Connecting Axle breathers to intake snorkel
Old 10-09-2012, 07:48 PM
FlameRedJK's Avatar
Originally Posted by ronjenx
I looked at the product, and at a thread that showed the installation.
The final line, after all the other lines are tied together, is connected to the line that goes from the stock air box to the right side valve cover. That's the line that feeds the crank case with filtered air for the PCV system.
I wouldn't want to have contaminated diff/transmission/t-case oil getting into my crank case. (Or into the air box or snorkel, if connected to one of those)
And like I said, drawing a vacuum on the gear boxes can promote water and dirt migration through the seals.
Seems to me like a bad idea.
Guess its not for you then
Old 10-09-2012, 07:49 PM
ronjenx's Avatar
You are correct, sir.
Old 10-10-2012, 06:48 PM
JKingAround's Avatar
I'm going to run mine up in the bottom of the roll bar drill a hole put in a grommet and run it up in the roll bar
Old 10-10-2012, 06:49 PM
You can get to it in the back wheel wells
Old 10-10-2012, 06:54 PM
ronjenx's Avatar
Won't that make the inside of the Jeep smell like gear oil?
Old 10-17-2012, 11:45 AM
AwdDude's Avatar
Anyone else got any creative ideas for mounting the axle breathers?
Sent from my EVO using Tapatalk 2
Old 07-20-2018, 03:08 AM
Xinarin13's Avatar
Did you ever do it?
Old 07-20-2018, 07:17 AM
BoraBora's Avatar
People have done this with no issues. I personally know two people, and they haven't caused a vacuum or whatever.
Then again, it's really pointless to go through all that work. Just extend them up. I extended the rear diff up into the rear tail light compartment. The front diff breather sits just behind the driver side shock, so just extend it a few more inches up into the engine bay. The 3.6 transfer case breather is already in a good location in the engine bay, up high and out of the way. Transmission breather is a PITA to access, so I still haven't done it...but it's really not that low either. You'd have to be fording rivers all day for it to be a problem.
Quick Reply: Connecting Axle breathers to intake snorkel
