Control Arm Drop Brackets? Yes / No?
Old Jun 18, 2014 | 08:13 AM
  #61
mpkelley20's Avatar
Bump steer with a 2.5" lift? I don't think that is what you are feeling unless your lift gave you 4" or so. Also, if that is the case, your flighty steering could still be due to low caster if you used the mounting holes for a 2.5" lift. You should get an alignment done to see what you caster is. Should be in the 4.5 degree range to minimize flighty steering without adding too much driveline vibration.
If not the case, flighty steering has a few other causes so start checing all your steering components like drag link. Those bolts tend to wollow out rather quickly if they are not super tight.
I've also heard great things about drive quality of using brackets rather than adj arms but for anyone who bashes on rocks, the loss of some clearance sucks and those stock arms bend rather easily. They might be cheap to replace but it sucks trying to get off a trail if an arm snaps in two.
Old Jun 18, 2014 | 10:54 AM
  #62
Da10A's Avatar
Don't forget to update us. Make sure the control arms aren't over-torked at both ends. Otherwise it robs a lot of smoothness in the ride quality.
Old Jun 18, 2014 | 10:56 AM
  #63
Bypass's Avatar
Flighty may be because you new some toe in.
Bump steer is a steering issue not control arms. You have any aftermarket steering components like a pitman arm and trackbar bracket.
FYI I just did te rancho brackets on my '14 and it took me less than 30 min all alone.
The trick is to turn the steering wheel to align the arm bolts.
Old Jun 18, 2014 | 12:32 PM
  #64
Val 2.0's Avatar
I did have the Teraflex Monster Trackbar installed at the same time as the lift... I bet everything was tightened on while on the rack...
Old Jun 18, 2014 | 12:41 PM
  #65
Ncb's Avatar
Ncb
Please explain. I've never heard this before. (Not being a smart ass, just curious)
Old Jun 18, 2014 | 12:49 PM
  #66
Val 2.0's Avatar
Just bought a torque wrench (Huskey) and tightened to the recommended spec, 75 ft. lbs. on the uppers control arms and 130 ft. lbs. on the lowers...
Old Jun 18, 2014 | 01:44 PM
  #67
kjeeper10's Avatar
Vet Army
Default Control Arm Drop Brackets? Yes / No?
Yea .. My 9/16 grade 8 are at 140 (uppers 80)
The issue is tightening when the axle is drooped preloading the bushings.
2007 Rubicon /2 door/6 speed
Old Jan 4, 2015 | 04:37 PM
  #68
Sierra141's Avatar
I just got done installing my Rancho brackets, and all I can say is wow. My jeep rides soo much better on the highway especially, and they are beefy. Thumbs way up!
Old Jan 4, 2015 | 05:13 PM
  #69
ShutterBug's Avatar
A thread on JK Freaks was just started that is very interesting. The author has some interesting things to say about drop brackets.
The truth about AEV geometry control brackets: a one year review
Old Jan 4, 2015 | 06:00 PM
  #70
Jeepstin12's Avatar
Originally Posted by WARLOCK
Drop Bracket = best for road DD use Adjust. contr. arms = best for off road use Drop Bracket makes a huge improvement, I notice immediatellly after installing the brackets that the steering feel is much better, much more precise and way less sloppy. But you loose a bit of ground clearance so you have to compromise.
this. And, with purchasing adjustable control arms, you have the option to get crawler joints with will provide a little more articulation.
