Control Arm Question
I just put a 4" lift on my JKU and i purchased the Freedom Off-Road Adjustable Control Arms. the Caster was set at 3.5 and causing massive issues with the death wobble. I wanted to see if anyone knew the length that these adjustable control arms should be set at for get the Caster to about 4.2.
You won't get (or shouldn't) a specific length. You need the shop that installed the lift to set the castor castor correctly.
