JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   control arm questions (https://www.jk-forum.com/forums/modified-jk-tech-2/control-arm-questions-211781/)
jacksonbmx23 Jan 2, 2012 03:09 PM
im stepping up to 35s and also plan to go to the RE 3.5 coils as well on my 2 door. In order to correct my pinion and caster angles would i need adjustable upper or lower control arms. i will eventually get both but my budget does not allow me to right now. also, i noticed that many of the big names are pretty much the same price, is there any brand that comes out on top? i was looking at the Rubicon express, rock krawler, full traction, and teraflex.
brink2177 Jan 2, 2012 03:10 PM
You should only need the Lower Control Arms. I have the Teraflex, and they are tough!
OverlandJKU Jan 2, 2012 03:15 PM
I have Teraflex front lowers and rear uppers.. I am completely happy with them...
TeamApex Jan 2, 2012 04:51 PM
I've had 35s with a 4" lift for about 2yrs and it's driving me nuts with the handling lately. After a lot of hours logged searching the forum I decided to go with Rock Krawler. Majority of the threads say front lowers and rear uppers are all you need to dial the caster back in. I'm so eager to install them that when they get delivered this week I'll probably put them on in the driveway even though it's barely 20degrees outside!
jacksonbmx23 Jan 2, 2012 09:33 PM
Does anyone know the reason for lower front and upper rear? Seems to me that lower front and rear would do the same
snopro269 Jan 2, 2012 09:56 PM
Yeah I ran into opening a can of worms on my 2dr when I got longer rear lowers. Spring perch kit, Currie Antirock rear swaybar, relocate/ remove rear control arm bracket. But now I'm running 38's on a 2.5 and 1 inch body !!
Like planman said front adj uppers or lowers. I'd get a adj front trackbar and get a good alignment.
jacksonbmx23 Jan 3, 2012 04:17 AM
Wow thanks for the explanation, much appreciated
nachorubicon Jan 3, 2012 04:39 AM
I second the rock krawler arms. Most of the well known brands offer a good product but I know that the RK stuff works really well and has the flex of a spineless gymnast on muscle relaxers.
jaker t5 Jan 3, 2012 05:10 AM
Now what about control arm relocation brackets you can get that fix the caster after a 3 to 4" lift , the bracket cost 100 a whole lot cheaper then ADJ arms
jacksonbmx23 Jan 3, 2012 06:05 AM
Also, how long will my stock driveshafts last with the 3.5 coils, I ride trails often but not usually anything to serious
© 2026 MH Sub I, LLC dba Internet Brands
