Converting a manual into automatic
I have a 2007 JK manual which i love except I whished I had picked a automatic. Not willing to trade in or sell. Would it be doable do convert? What would it take? Is it just bolt on?
Thanks,
Nils
Thanks,
Nils
It would be costly because you'd need to find the correct automatic (new one from the dealer would most likely cost a few thousand dollars), replace the radiator and add transmission cooler lines, you would need to change parameters in the ECU aswell, also you'd need all the linkage required to convert it from manual to automatic. The parts alone would run into the thousands of dollars plus the labor if you're not doing the work yourself would cost in the thousand plus range.
Find the car you want that already has an automatic, changing from a manual to auto will be very expensive.
My JK is a 6 speed an my wife's is an automatic.
From personal experience, the JK automatic sucks. It i geared way too tall. It needs 5.38 differential gears and 35" or smaller tires to perform anything close to a 6 speed.
I would never buy another JK automatic.
If someone with a 6 speed is considering an automatic for wheeling in rock gardens, instead gear the diffs to 5.13s and run a Rubi 4:1 transfer case to get the crawl ratio you need.
If the purpose is to avoid constant shifting in Los Angeles type traffic jams, get a different vehicle for commuting.
The gearing of the automatic is just that bad with that much lost performance compared to the 6 speed.
Sent from my DROIDX using Tapatalk
As far as commuting w a stick goes, I find the JK much easier than a six speed car. I drive 150 miles a day round trip w my Sahara manual. I had a six speed civic si and was constantly shifting in slow traffic. I can chug along in second in crawling traffic between almost stop and 20 w/o shifting. Being up high is also great.
I love my manual, after reading what everyone else has said about converting. If you really want an automatic I would just sell it and buy an automatic. Not worth all that money to create it.
Having driven multiple copies with both transmissions, the manual is much better IMO (and that's what I own). It may not be quite as easy to rockcrawl with sometimes, but definitely puts more power to the ground and does what you want it to do, when you want it to do it.
And it is an easy manual vehicle to drive. I rarely have a sore clutch leg or get annoyed with having to shift.
