Currie Antirock System
Old Jan 3, 2012 | 05:47 AM
CJ THAT WENT JK's Avatar
Default Currie Antirock System
Looking into a rear sway bar system and this one keeps coming up. Looking to purchase one soon and was wondering who is running this or could give me input on another brand or is this the one to get? Thanks for the input.
Old Jan 3, 2012 | 06:13 AM
Come on there has to be somebody.
Old Jan 3, 2012 | 06:58 AM
jeep2007's Avatar
snopro269 is...
Old Jan 3, 2012 | 08:24 AM
spedly's Avatar
I'm running one what do you want to know about it?
Old Jan 3, 2012 | 08:29 AM
wecf's Avatar
I run 1. Works as advertised.
Old Jan 3, 2012 | 08:49 AM
Do you like it? Would you run a different setup? Stuff like that.
Old Jan 3, 2012 | 08:58 AM
walker's Avatar
I have had one also for the last three years, and I like it. It keeps wheels on the ground, with no hopping around on the tougher obstacles. I have not noticed any problems with body roll on or off road, but I drive it like a jeep not a sports car.
Regards, Walker
Old Jan 3, 2012 | 09:00 AM
Regards, Walker
Good to know. Thanks for the input.
Old Jan 3, 2012 | 09:51 AM
bo9roadking's Avatar
For those of you that have this setup, why did you change from stock? Did you see more articulation or better handling in the rear? I'm considering this setup for the rear end. I want to have the same onroad performance with improved offroad capability. The other option that I was considering is keeping my stock rear swaybar and adding RK's 3-link rear to my 3.5" RK Max Travel setup.
Old Jan 3, 2012 | 10:29 AM
spedly's Avatar
I like the setup. It feels much more stable offroad then having the swaybar disconnected. If you aren't running a lot of lift or you want to set it up for more droop you may have to trim the front body mount a little or the bar will hit it at full compression.
