JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Custom tie rod (https://www.jk-forum.com/forums/modified-jk-tech-2/custom-tie-rod-262463/)
jeeperjkjeeper Jan 30, 2013 12:52 PM
Custom tie rod
Have access to 7075 aluminum solid bar in a few sizes. Would i clear the diff cover if i use a straight tie rod with offset rod ends. I would like to use 1.75" or 1 5/8" at a min. If this can't be done i will have to see about bending the ends of the bar and go with straight TRE's
Pluke the 2 Jan 30, 2013 01:31 PM
have you seen where your tie rod is?
hooper Jan 30, 2013 02:20 PM
Rock Krawler tie rod uses the stock TRE for the drag link at the pitman arm. There aluminum rod will bend but will come back to original shape. Most normal aluminum won't do that with out special treatment/processing.
JKphotoshoot Jan 30, 2013 03:02 PM
It will work with GM 1 ton offset tie rod ends. But wheels need to be at least 16.5.
http://i371.photobucket.com/albums/o...FD7C19476F.jpg
jeeperjkjeeper Jan 30, 2013 05:58 PM
i know with those ends on the RuffStuff rod it will work but that is a 1.5" bar....i would like to run 1.75 if i can. Also wish someone made an offset TRE that has the stock D44 taper on it.
© 2026 MH Sub I, LLC dba Internet Brands
